2000 Camry Build
If you want quality mid priced, offer this $400 for the AudioControl 6 channel, see if he bites. Run 4 ohm tweeters 50x2, 2ohm 6.5's in the doors, 100x2 and 2 ohm coaxials in the rear at 100 x 2
Or this Zapco
4 ohm tweets, 2x100
2 ohm 6.5's 2x150
2 ohm coaxials 2x150
If you want a lot of power on a budget, this is bargain.
130 x 2 to 4 ohm tweeters
180 x 2to 2 ohm 6.5s
180 x2 to 6.5 coaxials
Or these (both Recoil to keep it neat) for 300 watts to the front/rear 2ohm 6.5comps/coaxials
and one of these for the tweets
2 x 210 (crazy overkill but hey,it matches and is priced right
Keeping in the recoil family but anew mini offer from Recoil
2 x 200 bridged at 4 ohms (tweets)
If you don't care that they match brands
this would dandy with 4 ohm tweeters, 2x50 watts
OR
Maybe this would be a good combo?
Seems like a good deal? $315 right on par for the budget!
Looks like a winner to me.
There's no amperage to worry about. 18 gauge to the DSP unit from the HU and the RF has dual 12 volt remote output leads, 18 gauge from the RF DSP to the amplifiers is fine as well. There simply is no benefit to running anything larger for your remote turn-on wires, just takes up space. You will likely need to split one of the two to the smaller amps and use the other diedicted out to the HCCA,
I got welding wire between my batteries and the rear ground and I think nvx wire from the rear battery to the amps
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
  • Locked
Why? Because of the owner? The cheaper won't be as clean as the SIA.
21
5K
CarAudio.com Regular
HardofWhoring
