2000 Camry Build
If you want quality mid priced, offer this $400 for the AudioControl 6 channel, see if he bites. Run 4 ohm tweeters 50x2, 2ohm 6.5's in the doors, 100x2 and 2 ohm coaxials in the rear at 100 x 2
Or this Zapco
4 ohm tweets, 2x100
2 ohm 6.5's 2x150
2 ohm coaxials 2x150
If you want a lot of power on a budget, this is bargain.
130 x 2 to 4 ohm tweeters
180 x 2to 2 ohm 6.5s
180 x2 to 6.5 coaxials
Or these (both Recoil to keep it neat) for 300 watts to the front/rear 2ohm 6.5comps/coaxials
and one of these for the tweets
2 x 210 (crazy overkill but hey,it matches and is priced right
Keeping in the recoil family but anew mini offer from Recoil
2 x 200 bridged at 4 ohms (tweets)
If you don't care that they match brands
this would dandy with 4 ohm tweeters, 2x50 watts
OR
There's no amperage to worry about. 18 gauge to the DSP unit from the HU and the RF has dual 12 volt remote output leads, 18 gauge from the RF DSP to the amplifiers is fine as well. There simply is no benefit to running anything larger for your remote turn-on wires, just takes up space. You will likely need to split one of the two to the smaller amps and use the other diedicted out to the HCCA,
HardofWhoring
