newbie looking for help with system upgrade
ill reach out to him and see what he says. tried signing up on that other site and i cant send a direct message. if someone has a contact i can use otherwise that would help alot. or tell him someone trying to contact him. in the meantime anyone recommend what would be generally a louder clearer system than the 2004 chevy tahoe LT bose system that i could get installed in an audio shop? the most common brands seem to be:
kicker
JL Audio
DD audio
Alpine
Beyma
PRV audio
Comando
Tharamps
what brands to stay away from? id ideally like to spend 1500 max with install. id that feasible more or less?
or reccomend some proper sound shops in the bronx or manhattan ideally? will travel if it can be done same day.
I screwed up and meant Skizer not ANS. ANS does really good work as well but isn't anywhere close to you in NY where Skizer is in the state. And if he can't help you then he knows a lot trusted installers in that area that he can recommend one to you.
Ignore the fool above me OP he just goes around here trolling people as that is all he does.
I wasn't the one that was wrong now was I?
hey guys thanks for the replies. im sure i could bring parts and what not to a shop..but my issue here is the "sound". i want something alot louder and clear than the Bose system in my truck. without hearing anything im hesitant to buy stuff and then have it installed and it sounds the same or lesser. at least i would think with what a shop offers if its not loud enough i can go louder. i dont want the doors deafened i need to hear this music lol the head unit is
https://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/FH-X730BS
with the Bose system in the 2004 chevy tahoe LT. its loud..but i want it louder with quality parts and brand. one place quoted me 1200 for a kicker replacement of speakers, amp, and woofer. im willling to go 1500-1600 for the right system and sound. another highly rated place seems to do JL audio and DD audio. i ideally want to walk into one of these shops...have them replace and upgeade everything that sounds louder and better than the bose system...with quality parts and some sort of reasonable workmanship warranty. im in the bronx,ny and will travel reasonably for good work. ive heard of jl audio and kicker but not all these other brands which is why im asking for help.
So.. The HU you got is only 2v RCA.. which It would have been a better choice have opted out for a 4-5v, but it does have T/A, and LPF and HPF on it which is a plus,And of course what you want and need i assume or you woudnt have picked it up.Most shops want you to buy what they SALE or have in Stock ..Hence SALE..Most will not install anything you bring without an extra upsale charge and will not give a warranty on the product and sometimes the install.Kicker has gone down hill since the mid 90s IMO.. Most theyre amps are still decent and I only like theyre KS25 1" Tweeters and theyre 3/4" tweeters(titanium) due that they take power and will scream on 50 watts or better.Actually sound pretty decent for the price.JL is over priced of my opinion, but they do make some dammned good amplifiers.. but you going to pay for them.. and there are competative brands for a much better price.DD is also very expensive but offer very quality gear that will last.. again$$$ deep pockets for the gear.
kicker
JL Audio
DD audio
Alpine
Beyma
PRV audio
Comando
Tharamps
JL = Over priced IMO
DD= Another Expensive deep pocket brand/ but High quality
Alpine= Higher end speakers are decent ,amps are quality Still good gear
Beyma= Expensive Raw speakers and components
PRV= fair to decent Raw drivers..Amps?? Ehh
Comando= Never heard of them.. Have look up but never heard of them
Taramps= Decent amplifiers for the $
Sub enclosure.. For Some bass/ sub stage)=
https://gpcaraudio.com/10-single-high-output-glue-it-screw-it-sub-enclosure/
Sub)=
https://soundqubed.com/product/hds3-2-series-1200w-subwoofer/
Sub Amp)=
https://soundqubed.com/product/s1-1250-monoblock-amplifier/
Front Stage amp and rear fill)=
https://soundqubed.com/product/s4-100-multiple-channel-amplifier/
Front Speakers)=
A)= http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=263740362261
OR B)= http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=283046165460
Rear Fill Speakers)= http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=253672307024
Amp supply kit.. I would get the 250 ANL fuse)= http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=113862621502
Ground Block)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=192821598383
Fused Distro Block)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=164553350279
Sub Amp Fuse and Extras)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=381265941685
Mids and High Fuse and Extras)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=391149304169
Amp 4 ga wire Poss)= https://gpcaraudio.com/4-awg-gp-merica-no-bs-ofhc-cable/
Amp 4ga wire NEG)= https://gpcaraudio.com/4-awg-gp-merica-no-bs-ofhc-cable/
4 ch RCA cables)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=162735255297
2 Ch RCAs for Sub amp)=
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=360638498486
Speaker wiring)=
https://www.amazon.com/dp/B009EADB2Q/?tag=caraudiocom-20
Sub wiring)=
https://www.amazon.com/dp/B0076SIARO/?tag=caraudiocom-20
Thats what Id put in that Tahoe for now.. Prob add 1 more 10" sub later, and a dual enclosure
Sub)=
Sub Amp)=
Front Speakers)=
Ground Block)=
4 ch RCA cables)=
Speaker wiring)=
Sub wiring)=
Wow
That took some time and effort
Nice post
Wow
Nice post
Didnt take very long man especially if you know what works and have purchased before.. Ive used just about the majority of those items I used in my 98 Xcab at one time except the older Polks,and wiring, and HU. Should get down pretty decent. Not an SPL build out, but should sound very nice
UptownTahoeNYC
UptownTahoeNYC
Bronx, New York
UptownTahoeNYC
