Need help with issue
Bigredf150
CarAudio.com Newbie
I’m having an issue of my amp going into protection mode as soon as the bass starts to hit but once it stops the green light comes back on. So far I’ve checked the wiring, re did the ground, tried a different amp and that amp did it as well.
This issue started after I flooded my truck and at WOT the bass went out and it blew the fuse. It’s a 50amp fuse btw. Any help would be appreciated, thanks!
What subs do you have? Model # and Brand? What is your final Ohm load? What amplifier are you using? Model and brand? What type of vehicle is this in? What type of electrical system do you have in the vehicle? Upgraded or Stock ? Size of battery like CCA/CA/RES? What id WOT?? Need information to try to help locate the culprit
Bigredf150
CarAudio.com Newbie
Bigredf150
North Carolina
metalheadjoe
