Will my setup work?!? HELP
tankdylan001
I have just recently bought:
1x Alpine type x 12" woofer
1x hifonics brutus 1700.d
The alpine max wattage is 1000 watt RMS and the hifonics amp wattage is 600 watt RMS running at 4 ohms.
I'm just wondering if running this amp and sub at 4 ohm would work?
I bought these items yesterday and i am waiting for them to come i'm just unsure :/
Ya it will work fine. I'm assuming you have d2 sub so why not just run at 1 ohm and set your gain accordingly.
Because at even 2 ohm operation that amp is working 4X harder, that it was at 4 ohms and sound quality suffers. Drop it to 1 and you're another quadroupleing in heat.
I would ask why buy THAT amp if you intended to run 4 ohm?
My advice is to try 4 ohm operation and see if that's enough for you.
d2 sub? sorry im kinda noob with this stuff
---------- Post added at 09:55 PM ---------- Previous post was at 09:55 PM ----------
so go ahead with running it at 4ohm?
okay so if i wire it to 2 ohm it will run at RMS Power of 1200 RMS.
Thats all good?
oh and what do i sacrafice when i wire it to 2 ohm rather than 4 ohm?
Sorry im new to this stuff
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
One Of my favorite sites to gain some information over the years. Excellent! I would deff. Bookmark it!!
38
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
tankdylan001
tankdylan001
Australia
tankdylan001
    May 18, 2024
    May 18, 2024
