which sub setup
swc204
The crossover is built onboard the plate amp.
Porting it would be a good idea, to get the most out of 250W...tune very low, 20-25Hz. You'll have to run the T/S params through a box calculator to get the net enclosure volume and port lengths.
23Hz should be fine. I doubt dropping the tuning 3Hz is going to be worth redesigning the box.
If you go with that circular port design though, I would recommend Aeroports to reduce chuffing...
*shrugs* personal preference
yes indeed the flared vareity of ports are quite decent
I would use their printed specs, if going with their enclosure...no need to make it bigger in that case.
If you were to lower the tuning frequency, you'd need to compensate enclosure volume accordingly.
swc204
swc204
pierre, SD
JimJ
