Which Cap Is The Best One?
what exact brand and model is your amp? what size wire do you have going to it? are you sure you have good grounds? is you amp hooked to the battery or a fuse box? (yes i've seen that done before) why don't you try doing the big 3?
I BOUGTH ON CIRCUIT CITY , TSUNAMI GAUGES IT WAS ONE OF THE EXPENSIVE ONE I THINK IT WAS FOR 850WATTS GAUGES
mazda what. you need to be more specific in all your answers. and lose the caps lock man
its a mazda 626 98
i dont know if the state has to do with all this u know the battery cause since i live in florida maybe the hot weather
Im pretty sure you got the tsunami brand 4 guage wiring kit. should be more than enough for a 500 watt RMS amp. now, answer the other questions!
Do you mean that the rpm gauge jumps up a little bit when the bass hits? My car use to do that and I dont think its anything serious I had a cap and a yellow top at the time too. My cap kind of worked but I would definately do the big 2 first. My ma cap wouldnt hold its charge after being disconnected for a little while 5 hours or so. I ended up getting rid of it and putting my amp in my truck
no they dont jump up they go down then up
"how does that make the situation better? instead of one battery to charge he would have 2. if he had an HO alt. and proper wiring i would say yea."
Not really, if you had 2 batterys itd put less strain on the altenator. JUST BECUZ IT DOES.
how does that battery get charged? the alt has to charge 2 batteries now.
jesus christ after reading through this thread i have gained a lot more respect for special ED teachers.
GReddyBooSTer
GReddyBooSTer
FL
stones
