Which Cap Is The Best One?
ok ***........Once the battery is fully charged to 12.6 volts, it requires less power from the alternator. This system of discharging and charging is called a cycle. If a battery is drained until it is nearly dead, the charging process completes what is called a deep cycle. Most automotive batteries are not capable of deep cycling and typically cannot handle this type of use more than once or twice. Having 2 batterys will keep it in a charge cycle cuz they wont get low as easily, and it wont have to go through deep cycles. Make sense, dumbo?
Or you could just get a deep cycle battery...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
But the power still has to come from somewhere...
All this over a 150 watt amp //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Answer, your car has a very tiny motor and a very tiny alternator.
Get the motor tuned up and replace your existing alternator with a high output model.
And I will say it again.
I told you not to buy that amp......
http://www.caraudio.com/vb/showthread.php?t=109088
This is its actual 14.4 volt power output.Pyramid 712X
75 watts RMSx2 @4ohms
150 watts RMS x1 @4ohms bridged.
Is 150 watts RMS enough for your needs?, cause thats all your gonna get from this amp.
GReddyBooSTer
GReddyBooSTer
FL
stones
