What sub is this?
That's a warden. If the guy doesn't know that it's probably stolen or he doesn't even have it and you may get shot/robbed/raped/eaten when you show up with cash to buy it.
I messaged with the guy a little and he seems legit. They are d1 so i was planning on running two taramps 3k's to it. I saw that 7-8 cubes would be good size for it?
I would think 9-10cu, but you would be running almost double power. I wouldnt go smaller than 8
I should be able to squeeze that in. Ive heard they can take 5k so i think tuned clean and after box rise i should be safe. Ideally id like to get a taraps 5k and run that but its d1 so i cant run the taramps at 1 ohm. So i need to get a 2 ohm 5k or be gentle on 2 3k's
You can do like 7.5 min but optimal is 10+ least my 21DP says that
I ran 11 cubes each with my 2 21"s. Get a 2ohm Taramps 8k. The 5k isn't worth it IMO. Pay a tiny bit more for the 8k.
I think 11 cubes will be too much for me to fit. Ill have to do some measuring to see what i have to work with. I should be able to get around 9 cubes. And if you recommend the 8k then ill probably just run 2 3k's since I already have one of them. I might not even bother getting this sub in the end. I was thinking to buy this and sell off my xfls. Plus ill have to get some stout electical setup
241
383
491
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
811
526
BSchrowang
Budget Builder
BSchrowang
Peru Illinois
BSchrowang
    May 16, 2024
    May 16, 2024
