Were can I buy these
Looking to buy a few of these pads. One side has adhesive and the other has a magnetized side.
Hey check ACmoore or walmart all you need is project magnets it has the adhesive and its a magnet
i just used the 3m double sided tape to hold my antenna to the bottom of the rear window when i had sirius. held it on for 2 years in the elements with no problems and easy to remove when needed.
i don't think the pad itself is magnatized the magnet is in the antennas the pad is most likely a thin piece of metal
this.. op if you are looking for the pads to use with the antennas it is just an adhesive with flexible metal.. the antenna is the magnet.. if you are looking for other purposes then carry on
i have one that i never used with my kenwood dd with navi, how much money you got?????
jk i'm going to keep it in case i need it one day.
From my collection a Pyramid PB401a amplifier from 1986. Class AB amp claims 100 watts per channel. Bridgeable and has separate gain control for...
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
706
Dammned that sounds good!! I usually dont eat out. But Hmm. Tempting
91
6K
bigaudiofanati2
bigaudiofanati2
Bridgeton, NJ
zackdash
maylar
    Jun 2, 2024
    Jun 1, 2024
