Weird Problem.Help!
They are not that old and I have a cable thats have the aux end and the rca end.So I plugg it into the amp and it plays fine so it's gotta be something else bisides the amps
and or also try shielding the rca wires from interference power / signal noise
you can try using some of that cheap split serrated plastic wire sheilding that is avalable from any auto store or walmart.
either electrical tape it or zip tie it shut every 12" so the rca wires dont pop out of it. if using zip ties to route wires - dont go crazy tight. snug is good but overly tight can choke off the wire and cause crappy conectivity from one end to the other thru the wire.
Thanks for the replys.I'll try it out. Where would I add the extra ground? I never heard of that before. Do I run the wire from the ground that's already there?
I would say that is definitely a signal issue. I know on some decks (mainly pioneer) it even helps to wrap bare wire around the output rca's then to a screw on the deck itself. I'm thinking you have a bad ground. Try tracing your factory ground from your dash that you tapped into. That may be the problem
Just a thought, does your vehicle have a factory amp somewhere?
Thanks for sharing the issue and sharing how to possibly fix any future issues for others
id put the subs in a ported box, and buy the proper amp to push them
29
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
iRastamon
iRastamon
birmingham ,al
gwaan83
    May 12, 2024
Brendon Jenness
    May 11, 2024
