Can someone help with weird headlight noise issue?
8 years and absolutely no problems with my ground distribution block. Try to refrain from putting down folks with mental developmental issues - not appropriate.
Did you switch to ground distribution block because you had a problem with chassis ground?
Give me a break with pc garbage. I didn't "put down" anyone except the weak people who choose to be offended. Being a sensitive baby - not appropriate.
I had no issue with the chassis ground, I used the block for convenience. No breaks here on the pc... Very appropriate to call out your inappropriate dig!!! I thought I had you on my ignore list. Seems that you were not, but I will correct that in a few minutes.
I didn't say anything inappropriate. I don't cater to sensitive babies. What's the word used in music to slow down the tempo? Whats the opposite of "advance" when you are timing ignition? Words are nothing without intent.
Matthew Edward
CarAudio.com Newbie
Matthew Edward
metalheadjoe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
