Amp problem
keyser318
CarAudio.com Newbie
Hello,
I have an amp that is about 25 years old. Worked fine when I took it out after 3-4 years of use. It sat unused. I got the urge to install it and upgrade the amp to the sub in my truck. I ran the 8 gauge cable to the battery. Grounded it to chassis, I don’t think I had a good ground. So I grabbed jumper cables to just get it mocked up and make sure I had stuff hooked up right before final mounting and make sure I had a good ground. As soon as I attach either the ground or the positive the fuse immediately pops. I took everything off load side to make sure there wasn’t a short occurring from something else. When I tell continuity between positive and negative terminals, they are not shorted. Am I missing something?
When a fuse immediately blows upon connecting the battery's positive or negative cable, it indicates a direct short circuit somewhere in the system
Have you opened it up to see if anything leaked (caps) or looks to be shorted or charred?
Sounds like a dead short and most likely a big one. Power and ground reversed? A newly installed cable may be at fault but something is off.
The amp has fried and the caps have degraded the board even?
keyser318
CarAudio.com Newbie
keyser318
indiana
Jimi77
Giles
    Sep 4, 2026
