Can someone help with weird headlight noise issue?
Have an odd issue maybe somebody knows the answer to. I have a 2016 Chevy Malibu. I have a sound quality build. The odd issue is with headlights off, its quiet. With high beams on, it's quiet. With low beams on it has an annoying buzz. It's not super loud but enough to ruin soft music or sitting without radio playing. If i turn the head unit off no sound ever comes through, which i assume is because with deck off it probably shuts off the rest of equipment maybe. I've replaced both headlights with better quality ones, brand new and no change. The headlights are a single light that has both low and high in one unit. Thats what makes it even weirder. Its same unit on high beams but they are quiet. Any ideas? Thanks in advance.
UPDATE: Not sure if this helps figure out the cause but if the engine is off the low beams do not make any noise even after a long time. It's only with the engine on. Does this make a difference? Still trying to get car in to have grounds checked. Someone else told me the alternator or battery can cause this?
It's possible the head units illumination wire is connected to the cars illumination in such a way it accepts electrical noise. Perhaps to the wrong illumination source wire. GM cars need specific wire harnesses to connect aftermarket head units.
Aftermarket headunit or factory with LOC?
Aftermarket. High end sony.
When I install a system I ground ALL components to the battery neg, NEVER to the body. ALso good practice to replace the battery to ground 6 or 8AWG wire with 4 AWG. Even the amps ground is 4 AWG or larger as required to the battery neg. I use a ground distribution block to insure all grounds are at the same point. Never had any noise from any source, alternator, blower motors, HID headlights, ECM. You might try a ground loop isolator between the radio and crossover or amp. Sometimes the antenna ground may cause noise, I used to get antenna isolaters from PAC (https://pac-audio.com/) I looked on their website but can't find it. One other possibility, if the noise is coming in on the radio power line, perhaps use the radio power wire to operate a relay getting power directly from the power distribution fuse block through the relay. The radio will still power off with the ignition but have a clean source of power. Good luck,
Retired Trunk Monkey
If you didn't install it you shouldn't be troubleshooting it. Let the installer fix his own mistake.
But in response to let the installer fix it, they "Don't have time" as they said i'm being too picky. It was supposed to be a sound quality install and i paid good money but they said it's impossible to find every little noise. This is a very irritating noise so i want it fixed. I'm not going back to the same installer in the future, going to find a new one but I chose poorly apparently for this install.
The crossovers are another good suggestion.
Now it's a he-said/she-said/pissing match. I don't think you are sharing the whole story.
I could be all sorts of things, but I'd look for crossovers that are close to or have the 12v+ to the amp draped over them. I'd look for a ground that is near the tail light ground. I'd check the grounds in the engine bay for corrosion and consider upgrading the grounds. Check the HU ground. Make a dedicated ground for the HU. If the HU has a dimmer/headlights lead, I'd try disconnecting that. Make sure the RCAs are snug.
That's the cheap and easy stuff.
It's a lot easier and equally effective to use the chassis as a ground path.
Using a "ground distribution block" is just plain retarded.
8 years and absolutely no problems with my ground distribution block. Try to refrain from putting down folks with mental developmental issues - not appropriate.
Matthew Edward
CarAudio.com Newbie
Matthew Edward
metalheadjoe
