Tweeters cut out at high volume
I have some mb quart crossovers I can sell you cheap and I think am using the ones in the link if they are the qm200.2's they work real well, also I had the same problem your having if you can play the tweeter until it cuts out then feel the motor to see if it's getting raging hot that's what mine were doing until i switched to a tweeter rated at 70wrms now they don't get warm or fade out ever.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
hatedonmostly
throwin' hunnits, hunnits
hatedonmostly
Detroit, MI
hatedonmostly
    May 20, 2024
    May 20, 2024
