Tweeter Spheres - pics and examples
Keep hope u need to build these for us common folk
haha.
i'm a hands-on guy. i usually make it up as i go. if i had the tweeters i can make the spheres. if i had the vehicle also, i could figure the mounts.
making holes in wood is easy. finding a way to keep the tweeter secured while routing wires and mounting at the perfect angle - that is the hard part.
haha.
In my truck I wanna do something with a swivel mount...
with that swivel ball (nice find) the wire would be routed separately. so you'd need to dress up that as well.
i do like that idea. being able to aim the tweeters is handy.
and the new spheres sound great. so do the Vifa ring radiator tweets. Much better than the others.
I just died a little in side
I could get u tweeter dimensions
having the actual tweeter is the only way i could guarantee it would fit correctly.
can i make a hole in a wood ball for you? sure - easy, just tell me the outside diameter of the tweeter. I can i make it a certain depth? sure - easy, just tell me total depth + wire. if that is all you want, then yes, i can do that. you'll have to figure out how to make it stick in the hole, drill the hole for the mount/wire, paint/finish to your tastes, etc.
since its just an air line with no quick-connect its hollow thru and thru so u can rub the wire same as the hollow tubes
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
264
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
758
Tons of options in that budget, including the cost of installation,
10
814
It'll look like a "Hawaiian professional" did your install then 🤣
17
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
tat2bass
    May 16, 2024
    May 16, 2024
