Tweeter Spheres - pics and examples
Keep hope u need to build these for us common folk
haha.
i'm a hands-on guy. i usually make it up as i go. if i had the tweeters i can make the spheres. if i had the vehicle also, i could figure the mounts.
making holes in wood is easy. finding a way to keep the tweeter secured while routing wires and mounting at the perfect angle - that is the hard part.
haha.
In my truck I wanna do something with a swivel mount...
with that swivel ball (nice find) the wire would be routed separately. so you'd need to dress up that as well.
i do like that idea. being able to aim the tweeters is handy.
and the new spheres sound great. so do the Vifa ring radiator tweets. Much better than the others.
I just died a little in side
I could get u tweeter dimensions
having the actual tweeter is the only way i could guarantee it would fit correctly.
can i make a hole in a wood ball for you? sure - easy, just tell me the outside diameter of the tweeter. I can i make it a certain depth? sure - easy, just tell me total depth + wire. if that is all you want, then yes, i can do that. you'll have to figure out how to make it stick in the hole, drill the hole for the mount/wire, paint/finish to your tastes, etc.
since its just an air line with no quick-connect its hollow thru and thru so u can rub the wire same as the hollow tubes
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
tat2bass
