Thoughts on the MTX Audio THUNDER75.4 Amp or Focal AP 4340 amp
run a dedicated ground.
This was tried but no luck.
Also the amp is mounted on the back deck in the rear of the car - furthest point from the antenna .
A Class AB amp appears to be the solution to the problem.
This was tried but no luck. Also the amp is mounted on the back deck in the rear of the car - furthest point from the antenna .
i'm pretty sure not all class d's will do that man try a friends d class for 5 mins.. i replaced my concept with exact same model next day no problems..
could be the polk audio is just trying to throw you off because that particular amp model has some serious issues and they dont want a bad rep. Because even my buddy's old school corvette that has full fiberglass body has zero issues with both his class D mids and highs along with his sub amp.
It may sound funny but try wrapping the amp in aluminum foil and ground it to see if it’s the amp belching out all kinds of EMI and you could probably get them to replace if if you proved the amp was noisey, you could always threaten to contact the FCC about there Noisey amp.
Thanks everyone for all the input. After reading all your input I have narrowed the decision to the US Acoustics Barbara Ann and the Focal Ap4304. Can anyone comment on the quality and reliability of the US Acoustics amp ?
TIA
Bob
Thanks everyone for all the input. After reading all your input I have narrowed the decision to the US Acoustics Barbara Ann and the Focal Ap4304. Can anyone comment on the quality and reliability of the US Acoustics amp ?TIA
Bob
Don't think so as that's a new amp to the market.
Bob
idk about focal but peeps say they love their us acoustic amps.. lots of other 4 channels but for the $ that one looks nice..
Polk DB seem to always sound so much better than most for drop inns...
808
I treat my vehicles to an extent where they become some of the quietest examples of that vehicle. It isn't cheap if you're buying quality...
Looks like you could raise the back seat maybe 2 to 2-1/2" use longer seat bolts and washers and frame/mold in the under carriage cavity of that...
14
Bobd207s
Bobd207s
NH
BOOMINGRANDPA
    May 12, 2024
Brendon Jenness
    May 11, 2024
