the sad reality of my system...
I'm a little skeptical of 29mm of Xmax from the 15A //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I would email Ben or Jeremy at eD to get the full scoop. They could also help you in designing a box, more than likely.
ive been digging through the forums and man o man was there
some backlash on the 15A...
how do i email ben... just right from ed's website... i anticipate
that kaosmoon doesnt really come here much anymore...
i watched some ed pron over at realm of excursion... the 15A
definately gets moving... that 29mm is a little over an inch correct???
i would say they more that far... unless the videos were of their
last play...
i still dont think that a 1.5cube box (maybe 1.2 with 1000w daily) is big.
my tempest is in FOUR cubes. anything under\at 2 cubes is small.
i agree... below a cube up to 2 cubes is about small... 2 cubes to
3 and a half or so is medium... over 4 is kinda big... and well... we
all know that people build huge SPL boxes and walls after that...
Here are the T/S parameters out of my winisd program. I am assuming they are correct.
Qts: 0.326
Vas: 96.47 L
Fs: 28.8 Hz
Re: 6.770 Ohm
Xmax: 29.1 mm
Z: 4.0 Ohm
Qms: 2.740
Qes: 0.370
SPL 89.98 dB
BL: 30.18069
Dd: 12.43 in
Sd: 124.93 in^2
Heres the t/s parameters for the rl-p 15
RL-p15 2ohm DVC RL-p15 4ohm DVC
Qts 0.333
Qes 0.363
Qms 4.032
Fs 23.426 Hz
Res 3.66 Ohms
Ls 5.236 m
Lp 7.277 m
Rp 10.46 Ohms
Dia 330 m
(% shift) 23.7 %
Vas 163.0 L
Mms 290.9 g
Cms 158.6 u
Bl 20.76
n0 554.4 m
Xmag 27.4 mm
Xsus 27.4 mm
Xmax 24.6 mm
SPL/Sensitivity 89.43 dB
Added mass 212 g
Dude, why are you so stuck on the 15" thing?
I can tell you will be so much happier with something like 2 sealed RL-Ps. You need something that gets loud and sounds good in a small sealed box, but you wanna be able to go a little bit overboard with the bass. Two 12s will fit that bill perfectly.
Go with something like a pair of RL-Ps, OZ MEs, W6v2s (if price isn't an issue)... in all honestly I think thats the best way for the average joe shmoe to get great bass without taking up a lot of space and without having to try a million boxes.
g30ffr3y
soul destroyer
g30ffr3y
buffalo, ny
Hundreth
