Adding amps to factory infotainment system question
Cmberges1
CarAudio.com Newbie
Have a 2024 kia forte 4 speaker (basic non amped) system. Gonna add my old hertz components to the door and my sub to the trunk. I also have a JL jd 400/4 and 500/1 amp. My question is do I need a LC7i (or something) with these amps or will 2 pair of
Kicker 46KISL Wire-to-RCA Adapters​
Ran to the 400/4 and then pre out to 500/1 work just the same? With the front (strong) signal going to the 400 on the preout side.
Or
Should I run front level to the 500.1 and rear level to 400.4 (and Y the inputs)?
If it was yours how would you do it?
Thanks for the help as always guys(gals)
Or
To add your Hertz components and a subwoofer to your 2024 Kia Forte with the existing non-amped system, you have a couple of options for how to integrate your JL Audio amplifiers. Here’s a detailed breakdown of the options you presented:
### Option 1: Using Kicker KISL Adapters
You can indeed use the Kicker KISL Wire-to-RCA adapters to connect your factory speaker wires to the JL Audio JD400/4 amplifier. Here’s how it would work:
1. **Connect the KISL Adapters**: Connect a pair of KISL adapters to the front speaker wires coming from the factory head unit. This will convert the speaker-level signals to RCA outputs.
2. **Connect to Amplifiers**: Run RCA cables from the KISL adapters to the inputs of the JD400/4.
3. **Pre-Out to JD500/1**: After connecting the front speakers to the JD400/4, you can use the pre-outs on the JD400/4 to send a signal to the JD500/1 for your subwoofer.
This method is straightforward and should work well for your setup. However, be aware that the KISL adapters may not provide an optimal signal quality compared to a dedicated line output converter like the LC7i, especially if you're looking for high sound quality.
### Option 2: Running Front Level to JD500/1 and Rear Level to JD400/4
In this method, you would connect your front speaker wires to the JD500/1 and the rear speaker wires to the JD400/4. You would also use Y adapters to split the signal appropriately.
1. **Connect Front Speakers to JD500/1**: Use the front speaker outputs and connect them directly to the JD500/1. This will allow you to run the subwoofer off the front channels.
2. **Connect Rear Speakers to JD400/4**: Connect the rear speaker outputs to the JD400/4 for powering your Hertz components.
3. **Y Adapters for Signal Splitting**: Use Y adapters to split the front signal if you need to send the same signal to both amplifiers.
### Recommendation
If it were my setup, I would lean towards the first option using the KISL adapters. This method simplifies the installation and keeps the signal path cleaner for the front speakers. The JD400/4 can handle the components well and the pre-outs will allow you to integrate the JD500/1 effectively.
However, if you’re concerned about sound quality and want the best possible output, consider investing in a good line output converter like the LC7i. It will provide a cleaner signal and more control over your setup.
### Conclusion
Both options are valid, but I would recommend the first option with the KISL adapters for a straightforward installation. Be sure to pay attention to the gain settings on your amplifiers to ensure a balanced sound.
I encourage other members to chime in with their experiences or suggestions. What have you found works best for integrating amplifiers into a factory system?
So I've never used an LOC before, just the output from an aftermarket head unit. So are the passive rca (kicker) going to act like the aftermarket outputs or different? Also how big of quality difference would an active LOC really add? The hertz sounded incredible in my old car with the 4v preout so just wondering.
Because either way I have to tap into the speakers behind the factory unit so the only extra wiring I would really need is a remote I think.
Just looking for the best sound from my components.
Cmberges1
CarAudio.com Newbie
Cmberges1
Commerce GA
Cmberges1
