This is not a Sundown problem. I am willing to bet that this is a LOC or Headunit problem. Are you plugging the RCA's into the right section on the amp? There is no way that it is the sub amp pushing high pitched noises through the door speakers unless you have seriously fu-bared the install some how.
1) Are you using RCA splitters for each amp or 2 seperate RCA's ?
2) Are both of your amps grounded to the same location ?
yeah your right, ive never heard of any such issue with sundown, and many people onhere seem to run sundowns.Nothing I can think of. I'd just be really shocked if the issue is from your amp, especially two in a row. I've used Sundown amps and know several people locally who do/have as well, along with tons of people on these forums that do. I've never heard of a noise issue before though.
well wth is the problemNo, its sounds like user error. I've never had a problem with sundown amps.
lol no i already tried both.The sundown amp has 2 sets of RCA holes. 1 is for input, the other is for output.
You're plugging your RCA's into the output sockets.
Try plugging them into the other set labeled input.
I accidentally did it once before
its present when nothing is playing, when volume is on off, when car is on or off, at any volume with any source. cd, ipod, radio. etc.; with gains at very minimum or at max high pitch is present at a consistent volumedoes it have the high pitch when the gains are up and when the gains are down?
is it present when playing music?
Is it there when nothing is playing?
Is it there when your playing the radio or ipod or cd or all of them?
when you had your other amp connected, how high was the volume on the headunit and what voltage were the gains set to?
