Completed Sundown Audio SAEv4-150.4 4-Channel Amp 225x4 @2, 150.4 x 4 @4 Class AB! $275 shipped to lower 48
Doxquzme
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
Price
$275
Condition (1 worst - 10 best)
10
Boise
This is brand new, only taken out for pictures and to be bench tested cause nothing leaves here that doesn't work.
Very clean class A/B high output SQL amplifier. A bit too much for the mids and tweeters it was originally purchased for.
The unit is flawless.
  • 450 x 2 @ 4 ohms RMS (Bridged)
  • 225 x 4 @ 2 ohm RMS
  • 150 x 4 @ 4 ohms RMS
  • Hi-fidelity Class A/B design
  • Variable 12dB low & high pass filters: 40Hz-5kHz
  • Power and protection indicators included
  • Thermal, voltage, speaker short, and dc-offset protection circuitry
The SAEv4 is engineered with high-fidelity Class A/B multi-channel architecture, providing an ideal balance between performance and affordability. Leveraging the latest half-bridge technology, these amplifiers deliver clean, powerful audio signals in a compact form factor.
Featuring an all-new chassis and heatsink design with 33% more aluminum, this SAEv4 keeps your system cool even during intense listening sessions. The amp is packed with a variable subsonic, high pass and low pass filters, plus a 4-way protection circuit (thermal, voltage, speaker short, and DC offset). The variable crossover slope (LPF/HPF) and a high signal-to-noise ratio of 92dB further enhance audio quality, with an exceptionally low noise floor.
With an input sensitivity of 6 volts and up to 900 watts of output, this amp is ready, willing, and more than able to drive your car audio system with a new level of precision and clarity.
Product Manual
Specifications
  • Input sensitivity: 6V max
  • Signal/noise ratio : 92DB
  • Operation voltage : DC 10.5V - 15.5V power input
  • Dimensions : 17.95” L x 6.3” W x 2.75” H
Was Photo Included
  1. Yes
Was Note Included
  1. Yes
Doxquzme
Premium Member
Doxquzme
Boise, ID
Doxquzme
