Sub not working!?!?!?!
Wire remote cable to amp. Amp to ground. Amp has the negative and positives which you wire to sub. Amp gets power from battery. ill use one guage not 8. Read a forum about wires lol. Is that right?
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif :
(a) Your remote activation wire will be the smallest cable you run.
(b) Amp needs both power and ground and yes, it gets the power from your battery.
© There are only a handful of amps that will accept power cable as large as 1/0awg directly and those that will are going to have output levels that are likely higher than anything you might need at your experience level.
(d) The size of power cable you need will be entirely dependant on how much continuous power the amp or amps you decide to use will output.
Assassin 12- $90 + shipping
Knukoncepts 4 gauge kit- $25+ shipping
Phoneix gold xenon x600.1- ~$200+ shipping
That would be a decent startup system. Id put it in a 2.5 cf ported box tuned to 32 hz
what did he get banned for? unless he posted **** somewhere. someone is just being a fucctard. that's not right.
Unless it's another forum member who created a bogus username just to create trolling threads and they got found out via an IP comparison...
In that case it'd be just right //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Wow.That didn't take long. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
The title saying Banned doesn't mean all that much, though....anyone can make their user title read 'Banned'
yea, i thought you had to get to a certain post count before you could change you title...but if not i guess he changed it to banned...
correct. i hope that's the case. otherwise, someone's just a prick.
not to mention having banned in your title will get you banned. or at least the threat of being banned.
reptheoakland
reptheoakland
Oakland
PESteele
