Sub not working!?!?!?!
reptheoakland
1st post!!! Hey guy I just bought my sony xplod today and i gotta say it looks good. I bought an 8 gauge kit to wire it to my battery. I did everything to wire it but its not playing bass. I put the negative to the negative to that battery. Then the positive to positive. Is it because maybe i should wire positive to negative and negative to positive? It still makes a little noise but its not music.
pos to pos-neg to ground(bare metal on the car chassis)blue and white remote to remote on amp.rcas from HU to amp-amp out put to sub,pos to pos and neg to neg.Hooking up pos to neg terminal may be terminal to your amp,as well as your car.
DO NOT WIRE NEG. TO POS. you could have just grounded the amp on an existing bolt somewhere close to the amp. did you run the remote wire from the deck? what about rca's?
you need to do alot of reading around this forum before buying or installing anything. spend a while searching and reading. do a search on any equipment before you buy it. do not buy any more sony car audio.
i think im gonna get those 2 channel amps
it says you can take two channels and make em one. i found a 800 watt 2 channel amp when only used for one sub. Then get another sub later on //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
THANKS GUYS. I noticed what you said about the remote cable too. found what it is in my alpine book. Cant wait to hook it up tommorow
reptheoakland
reptheoakland
Oakland
PESteele
