4runnercrazy
Mattchu
is it possible, if so how?, i could hook up a sub (and amp if needed) to my old home audio reciver?
well right now i have my reciver hooked up to my computer, so as of right now im runniong 4 speakers.......as for jsut the computer i think u basically can only get the ones specially made for the computerive always wondered the same...only to my computer.
could i find those at best buy or would the net be the best place to go, and if you have a favorite site, that would be awesomeYou have to have a source of 12vdc current of sufficient amperage to run whatever mobile audio gear you're wanting to run.
This can be accomplished several ways.
The cheapest would be a car battery on a batt. charger if you have the extra battery to use.
The safest is to use a proper 110vac to 12vdc converter. The 35 amp I have in my bedroom currently (running a HU and two amps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif) was around $100.
The 52 amp power supply I have in my shop was...a bit more. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i dont know what its called, i got it from radioshack, ill try to find it online and send ya the linkhow do you have the receiver hooked up to the comp?
yep new to me toothat would be sweet... i have an old school receiver with the little needles on em...would be perfect if I could figure out how to hook it up to my comp...these speakers ****!!!
edit... whats a plate amp...this is all knew to me...and probably thread starter to.
yeah, u can go to radioshack and get thosewell i cant find it right now but it has two RCA Male (a red one and a white one) on one side and the hook up that goes into ur computer speaker port, it was like 6 bucks for a 6 ft one
