sub cuts out at high volumes!! Help
endofdays89
Banned
I know there are probably alot of threads about this, but my subwoofer keeps cutting out at high volumes! Its just my sub that cuts out, everything else plays. I have secured my grounds and charged my battery and it still cuts in and out. My amp is at 2 ohms which is totally fine because it is 1 ohm stable. Any ideas, why it keeps cutting in and out?
my voltage is fine. My amp does go into protect mode though.
my ground is attached to the top of the trunk. Its secured and tight
That might not be enough, most trunks are light sheet metal. Try attaching it to the rear strut bolt, or even the rear seat belt bolt.
endofdays89
Banned
endofdays89
missouri
boomzilla
