Sub cutout
AlpineUser
Bumpin
if i cut out a 12-12 1/2 inch hole that would be to big right.....isnt 12 inches from end to end of the ring........also could i make a ring to go on the inside so the sub would sit flush to the box?
btw this is for 2 12in. Type X's
any help is apriciated........I AM A N00B at building boxes lol
like livinlife said a 12" sub doesn't need a 12" cut out. Easy way to flush mount subs is to use a double baffle. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so would i cut the first baffle out at 12inches? then the second one at 9.5?
Yeah, the first cutout is for the sub to mount in then the second baffle needs to go around the sub so it needs to be 12 inches. I would go a little bigger than 12 though, maybe 13 or so. That way you can get it out easier and move it around once you drop it in. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
^Like he said . But I usually oversize by a 1/4" just so the sub doesn't fight me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
its easier to cut, i suppose, with the radius then diameter... just use a thin cardboard paper and make two points, 4.55" radius in between, and DRAW!
I think diameter most of the time. Been usng the jasper too long I guess //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
AlpineUser
Bumpin
AlpineUser
St. Charles Mo
danteBirosel
