Soft parts make subs take more power.
Was that directed at you? Calm yourself before you jump the gun kid...
I was supporting your point...
Sensitivity is not a viable way to measure anything really on a sub. Sometimes they use a 10k hz note and measure sensitivity there.... a sub will never see that high of a note if used correctly.
well as u can tell from my response your "support" for saying sensitivity is not a viable way to measure sq was confusing. it could have gone either way.
i simply cleared it up.
i am young, but not as young as you, but i dont mind if u call me kid, i like being young
The "standard" frequency for sensitivity is 1000 Hz -- most speakers are measured or calculated this way. This makes it not very useful for sub-woofers.
CMS has nothing to do with it either... Example :
I have a driver with a CMS of 140 uM/N and an Fs of 33 Hz with a Sens of 88.5 dB -- Qts is 0.272 for this example.
If I make the CMS 70 uM/N (twice as stiff) the Fs is now 46.6 Hz but the Sens is still 88.5 dB -- Qts also changed to 0.385
The second driver has more mechanically power handling as it is more difficult to move -- and low frequencies call for significantly more movement than high frequencies.
We can already see why Sensitivity is useless for low frequencies... typically a lower Sens driver (resulting from more mass or a lower motor force factor... not CMS) has MORE low-end extension for a given enclosure volume, actually.
While I'm here... I see alot of folks talking about sensitivity and/or MMS as THE spec for SPL woofers. They are not in and of themselves... Sensitivity depends on two specifications for the most part -- motor force factor AND mass.
What is really important here is the ratio of the two... for example if I have a driver with a BL^2/RE of 108 and an MMS of 223 grams the sensitivity is 85.5 dB -- if I take that driver a put a heavier cone on it but also make the magnet enormous for a BL^2/RE of 198 but with a resultant MMS of 301 grams to keep sensitivity at 85.5 dB... which do you think will be louder ? Based on our testing the latter driver will be around a full dB louder -- with an identical sensitivity.
Too many variables to even make the most simple of generalizations. There are always exceptions to any kind of rule, normally many exceptions.
soooo...this? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
  • Locked
Looking to sell two ZX 1500.1 not working lots of good parts that are hard to come bye as well as a ZX 650X4 Also not working lots of good parts...
Well..How about those Shoes?? High Heels?? Dresses?? Never room in the closet for my stuff. Ya.. Use the Guest Closet???? :LOL: :LOL: 💩...
21
sobe3yourself.
lordside gangster
sobe3yourself.
Orange, CA
hispls
    Jun 3, 2024
