Skar Audio build in a 2006 Pontiac G6
The wait is over! 4ft^3 tuned to 30hz after all displacements and such. Quad Skar VVX 10s will have a final load of .5 ohm and will be ran of a DAT Prototype hellfire 2500 should see a little over 3k out of it at .5
Updates ran out of sunlight will have to finish it tuesday! I have never built ANYTHING out of wood this is my first time building really anything so be easy lol i did well imo have to put on front and top and cut out out for subs and it will be done!
My first 45* ever!
Lol eager to learn really what flaws do you see?
Slot ports that don't fill up the whole width of the box restrict the air movement because you introduce a lot more corners. A "traditional" box that has a single large slot port on the bottom with a big 45 shoved in the back corner allows for great air movement whereas that design really blocks a lot of it.
Got amp today love the look of this thing solid black very plain no etching at (its the prototype) seller through in some goodies a plexi glass etching of DAT logo and name which im thinking ill use it on a amp rack or something he also threw in some quantum audio 1" tweets i have no use for but ill take em! Picking up some more 0ga sometime soon locally going to do a complete run + and - from front to back and get my alt back in and install comps finish box and buy subs
Bro you did not buy a DAT amp! WHAT THE FUCK WHERE YOU THINKING!
and on the box, it looks like you cut the sides 3/4" to short..... unless you are going to cut out the part for the port and slide it over instead of placing a front piece on it and using a flush trim bit on a router.
Yes i did buy bro been wanting to try one but like i said its the PROTO the productions models are what took a **** and yes im cutting the front to fit flush
Is that 1in mdf?
I'm diggin the build. I put up very similar #'s in MECA AS3 Ohio Finals a few weeks ago. I'm on stock elec with a 130a alt and voltage dropping to 11.8 (//content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif) and no sound dampening but I'm pretty sure I can break a 40.
I cant wait to see how the quads end up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
edit: forgot to ask how much did the spl meter set you back?
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
I usually build my own enclosures and didn't have the time to make another box, just happened to have the dual 12" box laying around. I see a 3.5...
Id keep with the warranty return. Id look at getting a different more reliable amp, and maybe Sale the Skar.. Thats me though. Seems like a PITA...
  • Locked
COMPLETED Skar Audio RP600.5
sorry been on bed rest due to back issues. Looking for max depth of 5.5” 2ohm load 350 watts 1ohm load 500 watts
g6ryder
g6ryder
Claremore, OK
GrindFrog
    May 16, 2024
    May 16, 2024
