Setting amp freq when using external crossover
Theride
NY
i have an AQ90X4 amp which is active capable. However, I purchased a miniDSP 2X4 to try different things. My issue is, I am not sure how to set the amp.
should I set it to FULL? HPF? when I set it to full, it seems its reproducing too much bass, especially the tweeters. What freq should it be if I flip it to HPF? Since im using an external crossover, should I still set it to switch to 10X or leave it on 1x? if i set it to 10x, wouldnt that be like setting the crossover points TWICE? once on the minidsp and on the amp....
basically, im not sure how to set the amp since im using an external crossover and not the onboard crossover for the active set up.
Theride
Theride
NY
maylar
