Explain this to me then. If one layer of RAAMat stops the rattling in someone's car door, and that's all they want, wouldn't it be cheaper to use RAAMat than SS? Isn't one sheet of RAAMat cheaper than one sheet of SS? I think the point the other guy was making is that RAAMat works well enough for some people. If SS provides X% less vibration or rattling that may be irrelevant if that degree of dampening is not needed.
This is an easy one.
If one layer of raammat is enough to acheive your goals, this means that 1/2 a layer of a superior product is enough to accomplish your goals.
What you can not seem to get your head around is surface coverage.
You do not have to cover 100% of the sheet metal to kill the vibrations throughout the entire sheet metal surface.
Do this.
Take 2 cymbols from a set of drums. They have to be the same exact symbol.
Cover one symbol with a full layer of Raamamt - 100% surface coverage.
How much Raammat did that take? 2 sq feet maybe?
Ok, now take half as much of Dynamat Extreme, Hushmat or vmax. cut it in to 2 sq inch pieces, then layer those peices like a checker board over 50% surface area of the second symbol.
The second symbol will actually be more dead than the firsts one. even with less surface coverage. This is because the second one is treated with a product that is far superior.
Now calculate how much you spent on the products.
If you spend less on the second symbol and got better results, how could you possibly still sit back and justify that Symbol 1 is treated with a better or a cheaper product?
Do the test. I am not making this stuff up!
ANT
