possible to fix short circuit on headunit? please help
  • 2
VoTran24
Bay Area
Today I installed my kenwood excelon headunit onto my other car. At first i got everything together fine. It played cd's and everything fine. When i stuffed the wires back to fit the cd player in, the power wire (I think) from the headunit got pulled too hard and it came lose and then one end of the wire fell and touch the metal of the headunit. Right after it touched the metal part i heard a little shock and then the head unit turned off. After that the head unit didnt turn back on anymore. I'm assuming that this is called a "short circuit." is it possible to fix a short? I thought that if a short happened it would have just blown the fuse on the HU or somethin but when i checked the HU, the fuse was fine. Can anyone help me? thanks
thats wierd, that happened to me b4, and the fuse in the power wire got blown. ur case is wierd, but it can be fixed, no worries
so you just replaced your fuse
Another weird part is that even if the head unit isnt working, my amp should still be able to turn on (i think) when the remote wire is touching it. But my amp still doesnt turn on. so i am guessin it might be somethin wrong with that wire, but it doesnt seem like it should. thanks for the reply though.
np, yeah i just replaced the fuse, but one time i blowed that hole thing until it smelled like burned plastic, i changed the fuse n nothin happened also , so i gave it to a prof. and i left it with him , after an hour i came back it was runnin smoothly, but he said he opened it from the inside , n used desolderin , n solderin and hooked up stuff that i cant remember, that was b4 two years, i blowed up that HU 5 times in a row, that was my first install. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and ur amp wont be able to work if ur remote wire is connected to the HU and not the ignition, then the HU should be on so that the amp turn on //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
wish u good luck any ways ,
Thanks for the reply. I checked the fuse box under the hood and found the blown fuse. I replaced it and now my system is workin again. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
869
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
VoTran24
VoTran24
Bay Area
VoTran24
    May 24, 2024
    May 23, 2024
