Please help me and my amp!!
  • 1
BASSBOY
Beware Of The BBB
hey, i have a mtx amp (pro 50x2) that is stable to 2 ohms, but i want to wire my 4 ohm kicker comp10's into 2 ohms and bridge it, this will equal 1 ohm, will this damage it fairly bad, if at all? i havent done it yet i just want more power for my subs. Is it a go/no go?
Thanks
I would chance it since it is a mtx amp but take it easy on the gain give it plenty of air and monitor the temp of the amp until you know what it can do
i ran a similar set up in my old car with an amp that was only stable to 2 ohms and tried to run it down to 1 ohm. it didn't work it overheated and fried my amp... i would really think long and hard before you do it man.
If you tried it I would monitor it very closely, It'll probably overheat quickly
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Hey everyone.. sorry I didn't get notified that i has more responses to this thread. The porsche sold a couple weeks ago lol I'll miss it but I...
29
4K
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
BASSBOY
Beware Of The BBB
BASSBOY
Alix, Alberta
    May 24, 2024
    May 23, 2024
