neo_styles
AKA Pop Twidget
Using the fader lowers voltage through the channel you're fading away from. That's probably why the eq adjustments aren't helping even with your gains at minimum. I'm guessing you cooked your tweeters by playing frequencies they couldn't support. Consider getting those replaced soon.Yea, al already put the tweets on a passive set at 3.5. I just didnt at first, adding the passive crossovers was a loose end afterf a 20 hour install.. So i ran them at 400hZ. But idk, depending on the song or whether the quality is good, itll crackle. 90% of songs it wont though. Still thinik idamagved the tweet. Using fader helps alottho than k god.
P.S.
When using fader, your lowering gain? I didnt know wheteher it was volume or db...
