R-Blox is asphalt with Mylar facing.also, any opinions on r-blox?
I don't think you can really compare FatMat, P&S and eDead. IMO, they all fall below my minimum standard for use. I want a butyl adhesive with an aluminum foil constraining layer that I can install with 100% confidence in its reliability. I'd put Cascade V-Max, Second Skin's Damplifier and Damplifier Pro in the top tier, Dynamat Xtreme a level below them and RAAMmat BXT and Ultimate from the Canadian company B-Quiet a level below DX. RAAMmat is the least expensive product I would consider. Each step up brings enhanced performance.so are you saying in comparison to edead, that fatmat and pand s arent as good? if im hearing correct it is better to use the butyle deadening, and not the asphalt? if so edead falls into that category. even though it has the thin mylar backing and some possible sticking issues? im not 100% sure if you are saying its better in comparison to those. like i said, i have no experience other than dynamat. is it a butyl or asphalt compound? and rudy you sound like youve actually tested and used these. other than raamaat, and second skin, what would you recommend as a third, all other variables aside. no spray adhesive, no dynamat either.
That's an excellent way to put it. It's the best of not the greatest. Kind of want e-love you now for saying those things and turning me on.....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gifRAAMmat is the least expensive product I would consider. Each step up brings enhanced performance.
Glad I could help //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifThat's an excellent way to put it. It's the best of not the greatest. Kind of want e-love you now for saying those things and turning me on.....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
You two should serious start up your own Deadening business. You guys seem to jump on every single deadening thread.Glad I could help //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It also interferes with the interface between the adhesive and the sheet metal which is where a lot of the conversion of vibration to heat occurs (with butyl, not asphalt).also, one thing to add. i think when people are deciding to add spray adhesive to the surface before adding the deadener, it sounds to me like you are setting yourself up for failure. applying a solid adhesive to a liquid adhesive (even if it does dry solid) should be less adhering beyond the poor adhesive properties of just the deadener. are you all actually cleaning the surfaces very well first with an alcohol or solvent?
I have my own business, but I don't sell "deadener." I think it has a limited role in the automobile, personally. Constrained layer damper, that is. There's just so much more out there when you appreciate the science and engineering behind the right tool for the job.You two should serious start up your own Deadening business. You guys seem to jump on every single deadening thread.
... just a thought.
Seriously. I have Protecto Wrap brand products in a few spots in my car. They make a version with a white mylar backing on it that's a little nicer than the older stuff. But the hell if I'm going to use that to deaden anything.Since you're determined to buy asphalt, you'd save yourself some money just driving to Lowe's and buying P&S directly. Oh well.
Not sure why you posted the question in the first place. To keep costs down, you use less of a decent product and get better results - but we've already been through that. It really doesn't matter if the car is a junker and you know for a fact that it will be crushed in a year or two but if not, you just screwed yourself or the next owner. You also gave money to someone you had been told can't be bothered to be straight and direct about what he's selling. You wasted a lot of people's time.well for the cost, it was either fat mat or peace pad or eDead. the latter two looked very similar to one another, but the fat mat has the thicker aluminum contstraining layer. while i do like the idea of the butyl, i dont feel too bad about the asphalt. i actually used a lot of old stuff in my last car that was straight leftover from ford factory. literally unbacked asphalt, and it did pretty well. i want the aluminum layer because i will be adhering carpeting to it.
I think what these guys are saying is pretty accurate.well for the cost, it was either fat mat or peace pad or eDead. the latter two looked very similar to one another, but the fat mat has the thicker aluminum contstraining layer. while i do like the idea of the butyl, i dont feel too bad about the asphalt. i actually used a lot of old stuff in my last car that was straight leftover from ford factory. literally unbacked asphalt, and it did pretty well. i want the aluminum layer because i will be adhering carpeting to it.
