DB meter?
efm80
does anyone know where to buy a reasonably priced DB meter??? Lots of the ones I have found on the internet only go up to 110 or so.
also, this might be hard to answer but if someone could give a ballpar figure on what you think 2 12"Infinity Perfect in a 3.4 ported box tuned at 33hz being power by an 800 watt PPi PCX2200 amp would do in DB's???? probably really hard to be sure but approximately??? and how many DB's does it take to get really loud, vibrate you, your throat, tickle your nose hairs, and start seeing double a bit.
eddie
U want a termlab and that cost like $700.
and 138 db but it all depens on car / install. GL
138db is the answer to what my setup does... or what is loud, tickles your nose and gives you double vision????? thanks
Anything other than a termlab is pretty much useless when comparing on this site. And its hard to guess what kinda numbers your putting up because it depends on so many things.
You could try an Epic160 or a "Make it Loud" mic.These are both relativily cheap and will give you something to go on when making adjustments to see if you get louder.Unfortunitly the only number that holds any real weight is th TL which is kinda pricey if your just looking for a number.I would just go to a local comp and pay 10-15 and find out that way.
efm80
efm80
las vegas,nv
audioarsonal
