opinions on 15's
I know what the car looks like ive been following your thread where you said you were parking it but man I would love to buy them but I cant anyway Im no where close to starting my build maybe a month away before I start so I cant buy right now. I also only want about 1500rms per sub so I don't have to do a huge electrical upgrade
those subs dont need much power to move at all. its neodymium slugs. Some of the best stuff on the market to get loud. I bet one of them in a proper box will make you sh*t your pants.
and let me ask you how 2 beefy 12s and 2 15s arnt different other then the box size being like 1 or 2 cubes smaller
No its not 1 or two cubes smaller. its a lot more than that. You need to actually know how cone area and Xmax will affect port area which will affect useable cubic feet and port tuning. From your statement i know you do not even grasp this concept at all and you are in way over your head man.
Without the console and no upper limit he can probably pull off enough space assuming he's willing to build up to the track on which the seat slides. 60" across makes up for a lot, even with less depth if height isn't an issue the real limit will be mounting depth on the subs.
no im not way over my head at all if I got a fu 1750 12 or a 15 there isn't going to be much of a difference between the 2 they are the same subwoofer with the same parts that's what I was referring to
thank you finally someone sees that its possible but 13-14 in of depth I feel like wouldn't be a problem for any sub around 9 in of depth or maybe even a little deeper
What? It's twice the box which requires twice the port and it's a lot more cone area. You know 1 18 is twice the cone area as 2 12s?
big boom crew
big boom crew
valdosta,GA
oxsign
