**oldschool4me's 92 civic build**
oldschool4me
well doing an install on one of my cars. 92 civic. most of the install will consist of os audio. got the rear floor done and the amps that will be powering my highs framed in, also the rear midbass (os mtx blue thunder pro 6.75" woofers) installed. wiring ran from front to rear. two runs of 1/0 a + and - for rear bat, speaker wires, rca's, processor ta controller cable, remote power wire.
been a slow process due to weather and having time to get into working on it.
here are a few pics of some of what i have done so far.
first a couple pics of the '92.
now for a few install pics. i will post more as i get them.
going to have flush mounted amps processor, eq, etc. i will carpet 1/8th inch board and probably use velcro so they will be easily removable.
rear floor
tweeter amp, mtx thunder 102
mid amp, mtx thunder 304
thanks guys. also if anyone has done an install on one of these i was wondering if and how they ran thier speaker wire into the front doors. thanks again. more pics to come soon.
looking good...I think your wiring in the front doors is similar to my 89 CRX...the way I did mine wasn't very pretty //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i think i know where your going with that lol. and im not liking it. only way i see it happening too due to fronts being active.
I ended up front far corners for the Earthquake Screamers on each end of the dash....in the CRX...sorta A pillar...wire is well hid...The DD midbass...I sorta came out the kick into the door panel and taped the wire....I needed beefier than the tiny factory wires....it seems I tried with right angle drills without luck on getting into the doors....I'm thinking the pin holding the door catch can be removed to give more access for drilling ...if its a quality install....for SPL I wasn't that picky
little mixture of both for me, trying out some re sx 10s. has to be ported so i decided to add a midbass back there to pick up where they will lack in punch also one reason i picked up your processor:D
oldschool4me
oldschool4me
ep, ohio
oldschool4me
