Newbie need some answers!!!!
Vman1356
New to audio beside slapping a sub box n throw in in some speakers ... so right now in the planning stages of my build been buying speakers n Subs that I prefer now lookin to source out the electrical side of the build like amps batteries n how many I would need ?????!!!! Build so far consist of 4dr 02 Acura TL
Inside:
Kenwood head unit
250 amp alt
12 ds18 8" bullet midrange (3x ea dr)275rms 8ohm ea
4 ds18 super tweeters (1 ea dr) 200rms 4ohm ea
8 ds18 dr550 (1ea dr 4 top deck) 400rms 8 ohm ea
4 ds18 exl 10"(top deck) 500 rms 4ohm ea
Trunk:
Lid-
4 ds18 exl 10" 500 rms 4ohm ea
6 ds18 710 tweeter 150 rms 4ohm ea
6 ds18 dr550 400 rms 8ohm ea
Bass:
2 15" kicker comp dual coil 1000rms ea.
Would love some input what amps I should check out how many I'd need n how many batteries to run full system ????!!!!
Your really in Orlando? You guys get flooded over there?
---------- Post added at 02:20 AM ---------- Previous post was at 02:20 AM ----------
Btw, way too many tweeters/mids.
New to audio beside slapping a sub box n throw in in some speakers ... so right now in the planning stages of my build been buying speakers n Subs that I prefer now lookin to source out the electrical side of the build like amps batteries n how many I would need ?????!!!! Build so far consist of 4dr 02 Acura TL Inside:
Kenwood head unit
250 amp alt
Trunk:
Lid-
Bass:
if you are going pro audio, you 1000% need to go active as in you need a head unit that can set crossovers and slopes properly which means no current kenwood head unit on the market as of now can do it. You can go to their sub family which is JVC and they have active head units or pioneer. IT makes the biggest difference, EQ will not tame your mids and tweeters, only a properly done active tune will.
Without active networks you'll never get the full clean output out of your tweeter, you'll just get nasty peaky unpleasant ear shredding highs and mids that bleed too much into the treble range. Both of these together will make the whole system sound like garbage.
Yes I am for real just want a little insite on what amps to buy???have already bout a couple lookin for info on a 1 ohm 1 ch/ 2ch to push 8 ds18 250DR each are 8 ohm 200 rms???
Also a amp to push my 4 10s that are 400rms n are 8 ohm??
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
811
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
Wow. That's a nice truck. Where I live there are few cars and trucks that use only one amplifier to power the speakers. So already noticeable...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
Vman1356
Vman1356
Orlando fl
Boomin_tahoe
    May 16, 2024
    May 16, 2024
