newb needs help
  • 2
n1k86
Pa
I am a newb. I am going to upgrade the sterio setup in my car. I have a 2000 pontiac grand am se 4 door, w/ factory cd. The reciever has an equalizer on it, no idea the specs on it though. I have 3/4 in tweeters, supposedly 4x6's in the front and 6x9's in the rear. Any idea on what to do? Also, whats the deal w/ component speakers.., are they add on to what i already have, ie. going from 6 speakers total to 10?
Components are usually just upgraded into your stock locations but you could add them in .. say... kickpanels. The better bet would be to replace your stock speakers with these.
goto www.crutchfield.com and click on "what fits my vehicle" so you can see for sure what size your speakers are.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
n1k86
n1k86
Pa
mattj
    May 16, 2024
    May 16, 2024
