Need opinion on good 3000+ amp
No it isn't and since you're probably never going to go look it up for yourself or just can't wrap your head around the quote I posted, it's simply the ratio of the output impedance of the amp to the impedance at the speaker terminals.
Now go ahead and tell us which two amps you were comparing with your anecdote, what other variables changed, and how you did this A/B comparison?
I may be misspeaking about the exact differences between full and half bridge based amps, but damping factor does matter. I don’t have anything against you, and but I’ve done a good of research related to damping factor specifically and what controls it. I do know that it has to do with the power supplies and half bridge being 1/2 the rail voltage of full bridge, and that seems (IMO) to affect the damping factor. I get output impedance. That’s not the full definition of damping factor and what it does/how it effectively works.
Once you get wired right you will have to go through the gain setting process again. I would set your gain with your HI @ 80 hz. and getting everything dialed in. Then while listening to bass heavy music you can play with HU crossover at 50 hz., 70 hz., and 80 hz. to see which one you like the best. I personally like 70 hz. with my 4 - 8's.
So if a SAZ 3500 is half the rail voltage of NS1 the NS1 has a lower output impedance?
And you're still dodging the questions. If damping factor is important why would you even consider running .5 ohm load? Tell us which two amps you tested side by side with different damping factors and give us some details about the rest of the variables involved.
Man I would put those down too!! I just grabbed a Revolver Blood and Honey, Its all I got in the fridge atm man. They been in there a while with some Bluemoons starring at my azz for a bit. 👀 👀 👀😁😁
$10 a twelve pack. Beans and ham in the Crock Pot. I'm in redneck heaven right now. I'm also in a 45' fifth wheel on 2-½ fenced in acres by myself (and my dog). 😂
Sometimes you just wind up there at .5. Some people already have subs set up at .5 and buy an amp that can’t run them; the amp malfunctions. That’s why. I never said I’ve considered buying high damping just to run .5 ohms.
There aren’t any other variables involved. It was only the amps that changed. One amp had a significantly higher damping factor than the other. They were both older amps, but that’s when I started paying attention to damping. One was an audiopipe amp and the other and elemental designs, in my personal own instance. I compared them out of boredom.
I’m not saying that damping factor is a 1:1 ratio to rail voltage. I’m saying the way car audio amps seem to work is related to layout of the amps. From my studying, half bridge amps in the car audio application seem to be more expensive and have higher damping factors than their full bridge counterparts at the same wattage for subs. Speaker impedance changes, and wildly sometimes, and the higher damping amps seem to deal with that better.
Im in a 4/2/2/2 Brick on a corner lot tonight, but really enjoy going out to the 35 acres in the 2/1 cabin. Hopefully looking to move there perm. shortly and then to either 60 or 80 acres in a 1/1 this time next year. Be me and my Shollie and picking up a Belgian Malinois later to help keep some Bison together.
And full bridge amps can do the same wattage @ .5, 1, and 2 ohms. Isn't that and advantage over half bridge amps?
Nice! My boy Mattingly (named after an old baseball player Don Mattingly) likes his front porch. The 148.9 @ 31 hz. Dodge in the background.
I didn’t read the entire thread but did see the video. With a sub right behind you, be aware that even with a certain xover setting you aren’t totally killing the frequency. It’s still coming through just at a lower amount. Easiest thing to do is set the xover above 120 and play it again. If it’s louder then it may just be all the filtering you will get. If no change, then something is wrong.
CarAudio.com Exclusive
Ohio
