Bobbytwonames
Trigger Man!
Very possible. Could be that the jumper wire came loose while installing the sub too.It happens man. Easy enough to check with a DMM also and to make sure he is at the 2ohm load and not @8ohm that will generate higher frequencies through the sub as well
From what I've heard and experienced the SIA line is probably the best full bridge amp on the market. Chines board with Korean parts. I think his amp is perfectly fine. I've been running mine without and it never even gets hot. I'm team no fuse if that matters. And my shitt bangs low. IMO people are sleeping on the SIA line of amps.
