Need a car install connecticut
Tommy gunz
Hi im looking for someone that can help me install my car system or inst all for payment i dont want to go to a shop and have them tell me 1200 for a install its just crazy please let me know if anyone can help i have 2 12 in subs double din head unit and 2 6.5s 2 tweeters 2 amps all wires
I checked theres nothing every shop i called wants over a thousand and says its going to be 8 to 12 hours for 2 doors and 2 12s in a coupe
You may have to get into the grind then. Not too difficult, getting over the uncertainty of being able to handle the task is the hardest part. I or anyone here can help with questions along the way. Youtube is a big help on safely removing panels and dashes apart.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
126
187
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
140
Tommy gunz
Tommy gunz
North haven
audiobaun
    May 19, 2024
    May 19, 2024
