- Thread Starter
- #1,276
Very useful to me, thanks! Basically abouit what I was planning for:Running your system this way you will retain subwoofer level control right from the HU (you won't need the remote for the V9 sub channel and I would suggest you NOT use it because it adds an unnecessary component in the signal path that is redundant), you will also retain the EQing abilities of your HU…In theory if you stick to adjusting the freq's within the subwoofer region (at the HU) you'll have no problem shaping the subwoofer response…depending on the model of your Alpine HU you may also subwoofer TA adjustment.
Your HU may not have as flexible of tools as the DSP…but it certainly has some you can use.
Suggestions for channel usage and freq ranges (to start) would be:
CH 1&2 tweeters 4000hz HP
CH 3&4 5.25's 200/250hz-4000hz BP
CH 5&6 front 6x9's 60hz-200/250hz BP
CH 7&8 rear 6x9's 60hz HP (no LP)
Sub CH 70/80hz LP
Start with all crossover slopes @24db
This will give you a 3-way front, basically full range (60hz and up) rears for rear fill, and dedicated sub.
EQ and TA as you like.
"ilikeradios" posted and I copy/pasted:
I find it very reassuring that both your recommendations are approximately the same for a 3 way set up! That's what I'm gonnas go for when I get the cabling to do it correctly. I have a laptop with the Sound Manager program on it. The first thing I'm gonna do when I getJohn - you will not get proper staging at all using the door speakers as full range.
You will not be able to do any time alignment using them like that either.
I was hoping you were going to set your front stage up as a 3 way
door speakers running 60-250 hz
dash speakers running 250 - 4,500 hz
tweeters 4,500 and up
That would be the best way to setup your system based on the equipment you have.
USB connected to the DSP is save the existing configuration in case I ever have to have the battery disconnected again!
I think I will copy/paste your recommendations and email it to myself too! Thanks!
John Kuthe...
