Hertz Mafia
FEATHER RUFFLER
if you knew how you sounded to me you would just stfu.. lol
If u knew how you sounded to EVERYONE.. u would stfu //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
Hopefully you get a build log going. I look forward to it!Time and money sir…If I have one I don't seem to have the other…I'll be getting more locally active though…I really miss the car audio 'scene'. I wanted to attend the latest meet but I had family obligations that day. I would really like to pick the brains of some of the more experienced tuners in the area…I know I have a lot to learn.
I've been on an AudioFrog kick lately (speaking of Harmon…kinda)…Planning a Froggy 5.1 system powered by (2) JL 900/5HD's.
i sure know alot more than your *******..If u knew how you sounded to EVERYONE.. u would stfu //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
There will be for sure…I may actually name the thread 'My install's coming along nicely II' heheheheheHopefully you get a build log going. I look forward to it!
Not sure if model and measure will add up. A couple of those DIYMA guys in the area own RTAs so if any of them are close-ish to you that'd be worth investigating. I get out your way every month or two and own an SPL meter but that's worthless above 100hz or so.I would think in the limited duty of dedicated mid bass a 6x9 would still be preferable to a round smaller 6.5 mid bass…even a 6.5 with an exotic motor will still likely see higher levels of distortion if driven hard enough to match the sound of the 6x9.
What I mean is (when modeled) an AudioFrog GB60 needs about 3 times the power as the GS693 to achieve the same SPL…I imagine at that power level (about 300rms) there would be a loss in BL as the cone/coil has to move so much more…and power compression could become an issue. The 6x9 would have such an 'easier' time producing the sound.
My apologies if my concepts are a bit off…like I said still learning.
TC1000 is TC7 motor? I had some 2K's and absolutely loved them. Subs that actually play music nicely when tuned really low.There will be for sure…I may actually name the thread 'My install's coming along nicely II' hehehehehe
The plan is AF GB10's in A pillars, GB25's in upper door, GS693's in front door for mid bass, GS42 center channel, GS62's for rear fill. TC Sounds TC1000 15 for sub duty.
Here are a couple threads with to my current AF set-up:
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/626708-audiofrog-gb10-gb25-pillar-podz.html
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/626818-audiofrog-audiomobile-jl-audio-knu-concepts-false-floor-sub-enclosure.html
Processing will be handled by an Alpine PXA-H800. I allays wanted to play around with a set of Neo8 planers.Not sure if model and measure will add up. A couple of those DIYMA guys in the area own RTAs so if any of them are close-ish to you that'd be worth investigating. I get out your way every month or two and own an SPL meter but that's worthless above 100hz or so.
I do not believe that cone shape will be an issue. Assuming you can fiddle with locations/aiming and have some solid processing power you can likely work around anything that comes up and the shape of the driver should be very low on the list of potential problems. Have you ever heard planar mids/tweeters? They're freaking amazing and they're square or rectangular radiating surface.
What in the hell planar drivers have to do with our discussion?Not sure if model and measure will add up. A couple of those DIYMA guys in the area own RTAs so if any of them are close-ish to you that'd be worth investigating. I get out your way every month or two and own an SPL meter but that's worthless above 100hz or so.
Lmao how does a windshield of a dodge caravan look cool.
No way....4 months later and it's finally done?This discussion has become SO far removed from my installation which is now finished!
John Kuthe...
Sad part is. When something discussion worthy comes up idiots dont discussThis discussion has become SO far removed from my installation which is now finished!
John Kuthe...
Like running your mouth more than anybody here? Yeah that's believable.i sure know alot more than your *******..
Alot more goes into a driver than displacment. Also you are talking about a driver that will play 80 to 500hz where excursion is much less a design issue. Where tte very things we are talkimg about can make or break a driver.I would think in the limited duty of dedicated mid bass a 6x9 would still be preferable to a round smaller 6.5 mid bass…even a 6.5 with an exotic motor will still likely see higher levels of distortion if driven hard enough to match the sound of the 6x9.
