My install's coming along nicely
Alot more goes into a driver than displacment. Also you are talking about a driver that will play 80 to 500hz where excursion is much less a design issue. Where tte very things we are talkimg about can make or break a driver.
Even midbass can have complex passages where the driver tries to play 2 or maybe more signals inside a signal.
Anytime a speaker has to excurt alot its usually very bad.
In this case your not so much worried about a flat bl curve since your talking about very little mass and very little excursion. The real key is avoiding breakup,good dispertion patterens, proper dampening' and achiving great transiant response..
This still doesn't have anything to do with my installation.
John Kuthe...
8
Dude. You can find articles that back my **** up.. Jackass
Oh look matter fact i linked them in the post so he could read more in depth. I should have known your ******* can't comperhend.
I have better things to do than look for stupid crap regarding you.
its a chance for you to learn a **** thing and YES IT DOES jackass. I am explaining why your install *****.. lol
And how is that gonna help me get my DSP configured so anything works? Let's start there. Once I start hearing music again we can talk about how c r a p p y it is!
John Kuthe...
your a ******* EE. you can't troubleshoot a DSP?
I did not even try. Installer guy was playing with the RUX controller trying to find some type of presets to start from but could not find anything. I WAS trying to use the Windows Sound Manager program to try and get in to see things but it would not connect via the USB from the PC to the DSP. Then I had a physical accident with the $50 used Windows laptop whose mousepad had quit on me, the batteries ****** and I accidentally broke it's screen, so it became garbage fast! Now all I have to configure the DSP is the RUX controller, which like I said I haven't really looked at much. The Alpine PDF file of Owner's Manual documentation is clear as mud! Useless as far as I can see, Installer guy did all the stuff it said for startup and nada! I need in-person help from someone who knows about the PXA-H800 DSP.
And it's freezing outside right now and dark!
John Kuthe...
JohnKuthe
JohnKuthe
Missouri
JohnKuthe
