My first RE product build
lol yes I need the corner ones...easier than the ghey ones I have...I have 2" wood screws going in once glue is dry...I just didnt use any screws at first like I could have...learning process of building enclosures //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just have to screw the top on and then mount the SE. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
So what your saying is that if he had used screws in the enclosure then glued everything together, and then once the glue dries to remove the screws???? That's the most stupidest thing I've ever heard. I never use wood glue at all when building my enclosures....and yes I use caulking. Using brad nails is fine....but I think this sorta topic has been argued more than several times. I much prefer to use 1.625" long drywall screws on every single box that I have built. Screws is what holds the pieces of the "box" together...
you are probably the stupidest person that i've ever heard speak, and that's coming from lemans.
i say this as nicely and as respecfully as someone can..........your a fvcking dumba$$. now before you come back with "you dont know anything about building boxes" please.....read what i have to say. after building a few with JUST screws in my beginning days, and then using glues AND screws as of late.........you will NEVER have a box as strong as a glued up box. the screws are clamps, only for as long as the glue is drying. then by all means YOU CAN TAKE THEM OUT. IT MAKES NO DIFFERENCE! Moe only uses glue on his boxes, nothing else........but let me guess.....he has NO CLUE what hes doing.correct?
negativezeroz
Nothing Is Promised
negativezeroz
-salad fingers-
negativezeroz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
