JL 13.5 W7...... Will a JL MARINE 750 mono push my speaker?!!!
yes it will work as long as the ohm load is adequate, but your sub will be underpowered. theres nothing wrong with that and your sub might last longer becasue you wont be pushing its limit as long as you set your gains properly and dont clip the sub to death. the gain is NOT a volume knob
youll only be giving it half its power but theres nothing wrong with that. put the sub in a proper box and itll move.
Dont run two different amps, even though theoretically you could plug one amp per coil. Get a second 750 that matches yours if you must. Remember two of those amps will really eat batteries. I would consider making a much larger box for the sub instead. Those 13.7s really get down in 3.5-4 cubes net.
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
793
I have used the Wetsounds in the past with great success. They are loud and clear.
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
  • Locked
581
Dgilmore84
Dgilmore84
Kansas City Mo
ancorp
    May 24, 2024
    May 23, 2024
