JL 13.5 W7...... Will a JL MARINE 750 mono push my speaker?!!!
yes it will work as long as the ohm load is adequate, but your sub will be underpowered. theres nothing wrong with that and your sub might last longer becasue you wont be pushing its limit as long as you set your gains properly and dont clip the sub to death. the gain is NOT a volume knob
Dont run two different amps, even though theoretically you could plug one amp per coil. Get a second 750 that matches yours if you must. Remember two of those amps will really eat batteries. I would consider making a much larger box for the sub instead. Those 13.7s really get down in 3.5-4 cubes net.
Dgilmore84
Dgilmore84
Kansas City Mo
ancorp
