is this possible??
  • Thread starter Unregistered
  • Start date
  • Replies 7
  • Views 880
U
Unregistered
Guest
If I have 1 JBL 600.1amp running two 4ohm subs in parallel @2ohm's can I add on another 600.1amp to the same two subs and get the power out of the second amp aswell??Would I then be running two 600.1's to two subs and be getting the rated amp power of the combined two @ 1200 rms?? I know if I just use one amp per sub I'll only be running the 4ohm power rating of each amp which is 300 rms. I don't want to sound like a rookie but I am..lol..Any help would be much appreciated. Also I'll be running 3amps and my HU has 3 pre outs..If this hook up is possible could I use Y connector RCA's from one sub amp to the other to incorporate the fourth amp??
Sorry I forgot to log on..in? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif :eek: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
no i dont think you can bridge the powers together there only a few amps where that works, my suggestion would be to get a jbl bp 1200.1 then you would get 600 watts rms for each sun and they are only about 100 bucks more then the bp600 on ebay
yes you could use a y adapter just make sure it goes right before the amp then use more rca cables to run it to the other amp and i guess you could also just hook it up right at the back of your hu...that would work as well
Thanks for the advice everyone.But can anyone explain to me the reason why it can't be done and what will happen? Thanks again..//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
it just wont bc to bridge two amps together to one channel you have to take the negative of one amp and use the positive of the other amp, and more then liikley it will not produce any sound and if it does i wouldnt reccommend using it like that bc it isnt suggested that you do that and it may damage the amps very quickly
Ok I guess I'm not going to risk my amps by trying that out..lol..Just thought it might work.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Anyways thanks for the advice Panther. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
869
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
Guest
Mamemba
    May 24, 2024
    May 23, 2024
